Thread: galant 2003 v6 6A13 soho 2.5l
Showing results 1 to 6 of 6
    Icon5 galant 2003 v6 6A13 soho 2.5l
    hi i have Galant 2003 VR not VR4 its v6 2.5 the engine code 6A13 soho the modle code its EA5A i need the ECU pin diagram i have piggyback i make it twin turbo just i need the diagram to finish what i start to do
    plzzzzzzzzzzzz some one help me
    11-29-2009
    Chadds Ford, PA
    2,759
    Your best bet would bet to try a vr-4 forum. This forum is mainly USDM cars there are a few galants from others countrys on here. We do not have the engine you have so knowledge here on that is very limited.
    4,036
    here read thru this. If it makes any sense in Mitsu ECU designs then the SOHC diagram should be the same except for the ignition. All pins needed for wiring a piggy back controller should be the same - RPM signal, Throttle Sensor, MAS sensor...
    http://www.dnaelite.com/gf/phpbb/vie...hp?f=94&t=8421
    94 Galant ES Turbo 5spd, DOHC swapped
    94 Galant GS-x Turbo, AWD swapped
    Member
    01-18-2003
    Brisbane, Australia
    132
    what brand/model piggy-back ecu are you using?
    also what's been done on your 6A13 SOHC?
    Where r u from ??
    Sent from my HTC HD2
    '00 Mitsubishi Galant ES 4g64T (Project #1)
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    DUDE i have the same cuestion cause i got the same car (model).
