Thread: Reset SRS-light with OBD-scanner?
Showing results 1 to 3 of 3
    Did a stupid thing: removed both seats for cleaning and forgot to unhook one of the battery poles before disconnecting the wires to the side-airbags.
    Now the SRS-light stays on.
    I refuse to go to the garage and pay $100-120 for a two-minute job!
    Is there any way to buy a cheap EM327 scanner (or similar) and do it myself? Did this on my former, german car. Trickiest part was to find the right version of the software....
    I have a G8 from '98 (European GLSi 2.0 model)
    Fick inte du svaret på forumet? Alltså vårat forum på svenska?
    Dra plus polen på batteriet och ta en fika... kom tillbaka och sätt på pluspolen... KLART!!
    Thomas R aka Valpen
    CEO & Eventmanager
    Mitsubishi Club Sweden
    Former New yorker....
    94-10 60th Ave
    113 73 Elmhurst, NY
    School PS13 - then moved to Europe
    Try autozone.......im not sure if their scanners can clean that code or not though.
    other option that might work is to disconnect the batter for over a half hour and reconnect it. Most of the times that cleans up dead/false codes.
    P.S. if you do end up doing the battery pull your car will be acting up after the fact for a 100 miles or so. Dont be alarmed it is only the car remapping the computer with how the engine runs. It is normal for the galants.
