Fick inte du svaret på forumet? Alltså vårat forum på svenska?
Dra plus polen på batteriet och ta en fika... kom tillbaka och sätt på pluspolen... KLART!!
Did a stupid thing: removed both seats for cleaning and forgot to unhook one of the battery poles before disconnecting the wires to the side-airbags.
Now the SRS-light stays on.
I refuse to go to the garage and pay $100-120 for a two-minute job!
Is there any way to buy a cheap EM327 scanner (or similar) and do it myself? Did this on my former, german car. Trickiest part was to find the right version of the software....
I have a G8 from '98 (European GLSi 2.0 model)
Thomas R aka Valpen
CEO & Eventmanager
Mitsubishi Club Sweden
Former New yorker....
94-10 60th Ave
113 73 Elmhurst, NY
School PS13 - then moved to Europe
Try autozone.......im not sure if their scanners can clean that code or not though.
other option that might work is to disconnect the batter for over a half hour and reconnect it. Most of the times that cleans up dead/false codes.
P.S. if you do end up doing the battery pull your car will be acting up after the fact for a 100 miles or so. Dont be alarmed it is only the car remapping the computer with how the engine runs. It is normal for the galants.
