made sticky
1994 GS FYI
DSM/CSM Manuals
made sticky
old news
try this one
http://www.club3g.com/forum/showthread.php?t=102450
My revised thread
http://www.club3g.com/forum/showthread.php?t=108380
1994 GS FYI
DSM/CSM Manuals
It was autozone bein stupid swaps all done now dohc ftw
2002
4g64 dohc turbo 5-speed
gt30r @20psi stock block,mbc
2.5" tbe
evo 8 ecu and maf
large fmic w/ cx racing intercooler pipes
wrx injectors @ 100psi fuel pressure
EDIT: started a thread with my question
2002 5spd swapped
under construction.....
is there another link for the swap. Tried all the links, but they're all dead. Is there any updated links somewhere?
https://www.thegalantcenter.org/showthread.php?t=43258
try this if you need more search here or club3g there is tons of info out there
2002 5spd swapped
can someone please verify if this is true.. http://forums.evolutionm.net/3359490-post35.html that we can use a timing belt off a Hyundai Sonata 2.4 instead of buying cam gears and degreeing them. and also can we get away with using our stock water pump?
