Thread: 7g Tutorial Master List - READ FIRST BEFORE POSTING
Showing results 1 to 9 of 9
    08-01-2002
    Keokuk, IA
    8,348
    PLEASE NO OFF TOPIC REPLIES, THEY WILL ALL BE DELETED.
    IF YOU WANT TO ADD SOMETHING, PLEASE FOLLOW THE DIRECTIONS LISTED BELOW.
    For simple quick Question/Answer tips, please post in this format:
    Q: What years were the USDM 7g Made:
    A:1994-1998
    For Links to tutorials, just follow what has already been posted:
    Brief Description of the Tutorial: Link to the Tutorial.
    Thanks and Please follow the rules!
    USDM 7g 94-98:
    Trims: S; GS; ES; LS; DE
    Engines: 94 GS 2.4L 4g64 DOHC; 94-98 2.4L 4g64 SOHC
    Performance: 94 GS 160hp/160ftlbs; 94-98 141hp/148ftlbs
    Max HP: 94 GS 6000rpm; 94-98 5500rpm
    Max Torque: 94 GS 4250rpm; 94-98 3000rpm
    Wheel Bolt Pattern: 4x114.5
    Weight: 2755-2877lbs
    Wheelbase:103.7in
    Miscellaneous:
    Service manuals, diagrams, picx: Link
    Best Power Adding Mods + misc. hardware: Link
    Best Supporting Mods: Link
    1994/95 dtc (Error Codes): Link
    1996/98 TDC's (Error codes): Link
    Engine:
    1g 60mm Throttle Body Install: Link
    4g63t Swap: Link
    AFPR Install: Link
    Cold air intake: Link; Link2
    Distributor to Coil pack Tutorial: Link
    Fuel pump module bypass: Link
    JiP's 2g ECU Tutorial: Link
    Headswap Partslist: Link
    SAFC Install(94-96): Link
    SAFC Install(97/98): Link
    Turbo SOHC tutorial: Link
    How to delete EGR: Link
    How to rewire the ISC for 60mm TB: Link
    How to Install 7g ISC on 1g Throttle body: Link
    How to run 2g Aluminum/Stock radiator with a SOHC head: Link
    7g/8g: Replacing spark plug oil seals: Link
    Drivetrain:
    1g Transmission install: Link
    5spd swap: Link; Link2
    5spd Shifter Upgrades: Link
    5 speed swap for beginner 7G: Link
    Interior/Exterior:
    LEDs in gauge cluster:Link
    2g Steering wheel install:Link
    Aftermarket Gauge Installs: Link
    Black housing USDM headlight Tutorial: Link
    Clear Corner Tutorial: Link
    Cloudy Headlight cleaning: Link
    Front window fix: Link
    JDM Headlight Wiring Tutorial: Link
    JDM Power folding mirror Install: Link
    Painting Interior trim: Link
    Repin ECU connectors: Link
    How to run factory fogs and highbeams simultaneously: Link
    LEDs in gauge cluster: Link
    How to: Install OEM 94-96 Accord Lip on a 7G: Link
    Installing a Trunk Keyhole Camera: Link
    DIY: Permanantly restore your faded black trim to its brand new OEM glory... for $10: Link
    Moving the Battery to the Trunk: Link
    Suspension/Brakes:
    DIY Rear camber kit: Link
    Inner Tie rod replacement: Link
    Rear drum-disk tutorial: Link; Link2
    Rear Swaybar Install: Link
    Rear tubular control arm install: Link
    Adjustable rear toe arms 7g and 8g: Link
    4 pot Brembo calipers in 7g: Link
    Rear sway bars review 7G - 8G: Link
    All links are broken!
    i like the write up though!
    (91 Galant VR4 1036/2000)
    In The process of rebuilding.
    08-01-2002
    Keokuk, IA
    8,348
    I will fix them tonight.
    the links should all work.
    1996 galant s
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    The broken links were fixed, added more stuff
    Build Thread
    very cool thread, but am having trouble finding lowering spring in the suspension section, help please anyone? thanks..
    excellent organization of the tutorials, thanks for doing this
    jjj
    09-20-2007
    Sea Isle city, NJ
    4,098
    post it in 7g genereal forum and i'll move it to tutorials
    Build Thread
    It wont let me post says at the bottom of the screen I can but when I try says nope. Oh your Galant is the background on my smartphone. Inspiration. But I'm going blue. . That in my op is the sickest 7 I've seen. ...also I'm doing 1g diamante folding mirrors I tarted but the wife got mad I was taking our car apart again so I put the stock back on , took the D's all the way apart and am rebuilding them
    Me I'm a lil of both
