center of the bottom most likely
could you guys tell me where is the transmission drain plog on a 01 Galant?
I've spent the last 20 minutes but still couldn't find it.
thanks
Laz
How big is it? All I see is two probably size 7 bolt. Unscrewed one of them but
that's just a long screw. I was assuming the drain plug is much bigger.
I still can't see it. I say a blach vertical pan on the front of the transmission but those are really corroded bolts. Looks like never been removed.
I may post a video see if you guys can spot it![]()
It should be a flat looking screw head near your transmission pan, about 15/16 size socket to unscrew it.
I took a few pictures, let me know if you see anyhting like that.
http://s602.photobucket.com/albums/t...albumview=grid
go look at the manual to auto conversion tutorial. There's a picture of the trans with the fluid being drained out of it.
I don't have the manual that's why I'm asking dumb questions![]()
I have removed the driver side wheel and behind the plastic cover on the left side of the tranny there is a flat, huge bolt. rusty like hell![]()
see the hole where the trainsmission oil is coming out of? thats the bolt you must take out
