check the bulbs, wiring harness and your grammar
I got a problem today i came out of the car and found out that my brakes light were turn on i check the fuse its good i stay on anybody can help thanks
Your brake lights remain on even with your foot off the brake pedal?
It's either the brake light switch itself, or the little plastic stopper piece for the brake light switch has broken off, allowing the spring-loaded switch to remain in the "closed" position.
Almost 100% positive on this one...
EDIT: Brake light switch is located down by the brake pedal.
"Speed never killed anyone. Suddenly becoming stationary...that's what gets you." - Jeremy Clarkson
1997 Galant ES with '94-95 style front end and '97 style rear
my problem was the "relay" cost $10 bucks or switch it with another one there all the same.. good luck!
Eclipse GT 5 spd swapped
Rotor Glow Galant
Daily Galant
OZ Edition Eclipse
If that stopper piece fell out, it probably completely disintegrated. I never actually find them intact, I usually just find several pieces of the old stopper on the floor mat
Instead of buying another cheap plastic piece, just thread a nut and bolt into the little hole in the brake pedal where the stopper went. Then re-adjust the switch (The bolt head will be a little taller than the original stopper piece), so that the brake lights come on as soon as the pedal is depressed.
