Thanks for the pic Chris.
Cody, the display with the seat in it was actually the climate control, on the USDM Diamante, it looked like this:
JD, Diamante's are very common around here in the junkyard, try one near you to see if they have one.
-Greg
Did not even notice I posted a pic of a RHD interior.
Yeah I nabbed a couple out of 7g's, but the 2g eclipse, is the same as mentioned above.
The top button takes place of the release button on your stock shifter. The side is for o/d, but we don't have it in the 8g. The toggle has 3 wires coming out of it... I haven't had the chance to look into it much more yet.
Check your PMs, sir.
Vic, I'll be shooting you a text soon related to the above post...
Sent from my phone like a boss...
-Andrew
Before:
After:
It's real simple. You just have to modify the white stalk thing to fit the new one. They're really easy to swap if you dremel too much.
-Andrew
Also what can you put around the base of it like a small boot? Since of course you don't wanna cover the gear select
Thanks man I might saw it, but again I don't wanna start something I can't finish especially if I can't drive in between
heres a simple one theres another more detailed one but i cant find it
https://www.thegalantcenter.org/showthread.php?t=36559
Hey is the diameter of our shift knob 10mm? I think it is but I found this boss knob and wanna get it. It totally goes with my blue interior theme
http://www.ebay.com/itm/Toyota-Aurio...ht_3251wt_1163
Ok guys. For those of you that know I had problems with my HID fogs. It turns out like you said I didn't need a relay. My friend figured it out because one ballast was bad and the connection included with the HIDs weren't full hence no light because of no connectivity. We spent a while putting them in and here they are
Also I replaced the shift light with a blue LED one. Soon i'll follow the tut on here to seperate the letters from the light. Pics up soon
Lol thanks, I did a few things before I joined here like my exhaust, tints, cold air intake...wait I never did an engine shot. It's mostly stock but i'll do it tomorrow. I saw a tut on how to paint the cover and i wanna do it.
