Thread: Installing remote control central door lock - how?
Showing results 1 to 15 of 15
    Installing keyless entry - how?
    Hi,
    I want to buy aftermarket keyless entry. I want to instal it to galant '94 (lhd). I found that locks in galant are controled by minus.
    Central door lock has this two diagrams:
    Where to connect keyless entry?
    I don't understand what you mean by "central door lock".
    It is true the car requires negative pulse to a certain wire in order for it to lock or unlock. Usually these wires are found in the drivers side kick panel.
    central door lock - that thing, wich allows you to lock/unlock all doors in car at same time using one lock.
    And I want to add remote keyless. But I don't know, what wires I can use.
    When u buy one it usually has a diagram or booklet tells u how to install it and what wires go to what..... And yea man I couldn't understand u either I just guest lol..... He isn't from the US I dnt think
    Are the 7g Galants wired the same way as 2g Eclipses? There are some good tutorials on www.dsmtuners.com on how to wire in alarms/keyless entry. IIRC, the door trigger wires run to behind the radio.
    Thank you for that website :-)
    BTW I wan to install keyless entry to my galant 94, thats all. I have connection diagram for that keyless remote and I have diagram of my galant and don't know where to connect that (I know keyless must "send" a negative to some wire to lock and to another to unlock, but I dont know what wires I can use).
    03-12-2007
    Dallas TEXAS
    2,041
    for just a keyles entry setup it is very easy only six wires (about)
    I'm just looking for control wires. Wich of them are they?
    Why not tie in within the door at the three wires from cylinder switch red/green, black and green/white?
    Quote Originally Posted by w/oarctic7g View Post
    That's what I've looking for - color of wires, that comes from switch. I've seen about 5 variants to connect and I didn't know the right version. Many thx for all
    It is easy. But on a foreign G im not sure if the colors are same as USDM.
    This is a screen capture I took. Its from the Directechs wiring site, membership is needed. I looked up a usdm and it was the same as this picture which is for Canadian mitsus. Check both door harnesses.
    It looks the same as in diagram in first post. But I found a mistake here: theres changed positions of doors (master controller is on left door on lhd cars, but there's on the right door in this picture). These pictures are from oficial galant wiring diagram.
    I'll take some photos when I'll install keyless.
    As long as it works.
    Pretty sure that there are newer galants than 96 that are dsm's... hah.
