Thread: run1206's turbo build: Parts complete
Page 10 of 13 FirstFirst ... 678910111213 LastLast
Showing results 181 to 200 of 241
  1. #181
    It should go out tomorrow, I have it in the back of my car
  2. #182
    Experienced TGC Member run1206's Avatar
    08-15-2006
    Perth Amboy, NJ
    1,558
    ok, so i decided to get off my lazy ass and get this project moving again...
    installed the wideband yesterday afternoon (would have been sooner but rained for a few hours and stopped soldering). didn't take any pics but the wideband gauge and sensor are installed. the problems i'm having now is i'm pulling 2 codes (heater malfunction code, which i though i fixed with the resistors :( and the other is the oxygen sensor too high voltage code ) . car ran ok this morning on my way to work, no bogging and no jolting after disconnecting the positive terminal :shock: :D
    while datalogging, i see the front sensor only reading 0.060 volts (at most) and it's in open loop mode (but no bogging, thank God ) but the odd thing is the gauge. it starts at 7.4 and blinks a few times (i'm assuming a reset or system check) and then slowly creeps up to about 8.9. i'm thinking the signal wire is loose cuz when the wire moves around a lil, the gauge goes back to 7.4 and blinks again, so i'm gonna resolder that signal line again. also the 25mm stereo to serial OUT connection in the package doesn't match my serial OUT connection on my laptop (their connection has only 9 holes and mine has i think 15 [same as my flat screen's serial cable] so i'm gonna go to best buy to see if they have a conversion harness so i can program the sensor.
    as far as the codes, i did two 10 ohm 10 watt resistors in parallel (which should become the 5 ohms needed for the resistane of the front sensor heater wire [pin 3] ) maybe i made the connection wrong, but i think it's still trying to read from the OEM harness (which isn't attached to any sensor). after work today i'll try to take some pics and continue with the install.
    GOOSEY: i STILL can't get the second end of the -6AN fitting to go into the SS line :( i'll keep trying during the week. as far as turbo fitment, that will be this upcoming friday and saturday. i'll take pics and send them to you (or post them here) for further review.
    laxin: PLEASE let me know when i can get a chance to drop by and pick up the intercooler and crash pipe
    mtcavity: keep me posted if you're still available for next weekend
    run1206's Rear Disc Tutorial
  3. #183
    i still have the maft you lazy bum. want me to just put it in the mail?
  4. #184
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by qnz View Post
    lazy??? Denver told me he'd pick it up, he's lazy, not me (i guess he's still busy with his manual tranny swap)
    he has the SAFC with him still, gotta remind him to give it to you
    but yes, if you could, please ship it. sending you a PM with the address.
  5. #185
    kbeast
    Run Call me shoot i got your back for a day
  6. #186
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by kbeast View Post
    i gotta see how my next few weekends are, but i could drive down to VA for a "wrench day". we'll see
  7. #187
    Experienced TGC Member Galante's Avatar
    05-01-2008
    Manitoba
    1,589
    so far so good man! any update? Are you done?
    Tuned 2013 Evolution X GSR PB
  8. #188
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by Galante View Post
    thanks, only thing i have as an update is that i got an EVO fuel rail from GOOSEY2099, gonna see if i can revise my fuel lines to work with that. Other than that, i fixed up my wideband so i only have one CEL (system too lean), but that i can fix with the GM MAFT (which i'm still contemplating whether to use the gen 1 or gen 2 maft)....
    i've been hammered with mid-terms, career fair, and programming assignments that i haven't been able to do anything to the car yet. i hope to get the fuel rail in before mid november (most likely gonna do it in two weeks, that and to get the SS -6AN line in). I still have yet to get the gaskets for head -> manifold, manifold -> turbo, turbo->o2 housing, and o2 housing-> downpipe.
  9. #189
    10-18-2007
    Glen Burnie, MD
    1,314
    Ur getting there, atleast you got all the parts now. lol
  10. #190
    Drew has the intensity of a wet noodle for this build lol
  11. #191
    good luck with yours man i wish i can put those parts sitting in the storage on
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  12. #192
    Quote Originally Posted by QnzMostWanted View Post
    Another Authentic Statement
  13. #193
    04-10-2005
    NYC
    3,695
    lmao...i should be one to talk though...im finally about to get started with mine lol
  14. #194
    any updates on this???
  15. #195
    nothing has changed lol...at this rate, i'll be boosted before drew
  16. #196
    08-15-2006
    Perth Amboy, NJ
    1,558
    Fejery (spelling?) might sell me his downpipe which bolts up to my setup. just waiting on him to let me know when he'll sell it. I gotta get the evo ecu cuz
    1. turbo maps
    2. could also do the 5 speed swap as well.
    currently searching for that as well.
  17. #197
    Experienced TGC Member ZigenScarface's Avatar
    08-04-2004
    Westchester NY
    1,332
    UPDATE? lol
  18. #198
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by ZigenScarface View Post
    UPDATE? lol
    when i get my paycheck next friday i'm gonna try to find a 2003 or 2004 EVO ECU, then the parts list will be complete. Install will probably be done either over the weekend or the following week after, depending on how much time I need. Either will have a mechanic weld and install a DP or ask GOOSEY2099 to weld and install one for me.
  19. #199
    08-04-2004
    Westchester NY
    1,332
    if u need n e help with the install lemme kno ill b down to help
  20. #200
    i offered him the help too but he dont have a daily so he cant afford down time with his car
    '95 Kawasaki ZX9R
