Thread: EBAY Projector Headlights
Page 23 of 35 FirstFirst ... 1319202122232425262733 ... LastLast
Showing results 441 to 460 of 687
  1. #441
    01-08-2008
    Levittown NY
    2,786
    BGR glad to see the LED
    I suggested are working out for you they are beautiful.
  2. #442
    RadRICH - TGC Founder BGR's Avatar
    12-09-1999
    FLORIN - Sacramento, CA
    1,996
    Quote Originally Posted by 01galant01 View Post
    I had an H4 HID kit and upgraded the bulbs.The projectors already come with the harness which converts H4 to H1. It's simple plug and play. I just used the projectors harness to plug the bulb in, that way the high beams will also be functional. I will take pics tomorrow for clarification.
    Whatever happened to the picture? I've been waiting to see how you connected the projector harness to the HID ballast.
  3. #443
    Quote Originally Posted by BGR View Post
    Forgot bro. Nothing really special about the connections, really plug and play, but I'll get you pics tomorrow.
    2001 5 speed 4g64T
  4. #444
    12-09-1999
    1,996
    I just wanted to see how you got it done because the way I have it wired... there's got to be a better way. You say just use the wires from the projector, but correct me if I'm wrong, but I don't see how you got those to connect to the H1 HID bulb without going through the ballast, or having to clip the wires and solder them to the projector wire. The projector wire and the H1 HID bulb doesn't have a compatible connector on the end.
  5. #445
    12-09-1999
    1,996
    They Ebay seller I got my H1 HID replacement bulbs are selling them for $10.99 with free shipping. I paid something like $19 with free shipping a couple months ago.
    http://cgi.ebay.com/ebaymotors/880-8...Q5fAccessories
  6. #446
    I dont know whats different between our HID setups so I'll post pics of mine.
    This is the harness which came with the projectors.
    Low beam connection on the harness.
    High Beam connection on the harness.
    HID Ballast.
    H1 HID Bulb. As you can see, there are two male connections on the end. That it what connects to the projector harness.
    Connection between HID bulb and projector harness. Males on the HID bulb go to the low beam female spades on the prjectors harness and the other wires coming out the bulb go to the ballast. Maybe you have different connections on your H1 replacement bulb.
    Low Beam
    High Beam
    So, really plug and play. Pretty much unplug the low beam bulb and plug in the HID bulb.
    2001 5 speed 4g64T
  7. #447
    12-09-1999
    1,996
    Thanks for clearing that up. After seeing your pics and explanation, I know what I did wrong. I just didn't use the other wire (non-HID H1 wire) with the male ends to plug into the low beam female plug on the projector harness. I just removed this wire entirely.
    That's cool. Then all what someone has to do (that never had H4 HID's) is to buy the H1 HID kit.
  8. #448
    Just to clarify, so now it's been confirmed that with these headlights it's not necessary to have H4 HID ballasts with an H1 bulb? A complete H1 HID Kit will work just fine, correct? Same output and everything I'm guessing..
  9. #449
    12-09-1999
    1,996
    Quote Originally Posted by The Professional View Post
    Yes. If you never had an HID kit in your Galant and would like to buy one, I would suggest you purchase the H1 kit (for these projector headlights).
    Most of us already had HID kits in our Galants, so all we had to do was buy an H1 HID replacement bulb. Again, if you never had an HID kit in your Galant, just buy the H1 HID kit from Ebay and follow the directions from 01Galant01 in order to plug the bulbs in and get them working. I'll put together a more detailed tutorial later since this seems to be a confusing topic.
  10. #450
    New Member USMCSKYLINE's Avatar
    04-01-2009
    Florin Rd, Sacramento, California
    55
    no kidding ;)
  11. #451
    You are here entirely tooo much!! Serstylz2's Avatar
    09-10-2003
    Charlotte, NC
    4,462
    I'm gonna go with a regular hyper yellow H1 for high beams, and get some h1 HID replacement bulbs for the low beam
  12. #452
    All HID ballasts are the same. It is the bulbs that differ in shape to fit your preference.
    2001 5 speed 4g64T
  13. #453
    thats exactly what i was thinking.. just didn't wanna seem like an idiot if i was worng lol
    I'm so excited we finally figured these lights...--- time for the purchase :D
  14. #454
    hey where did you guys buy your 194 LED's?
  15. #455
    12-09-1999
    1,996
    I bought 20 LED's from this person (selling these to USMCSKYLINE):
    http://cgi.ebay.com/ebaymotors/ws/eB...3A11&viewitem=
    And 16 from this person (these are the ones I'm using now):
  16. #456
    12-09-1999
    1,996
    Not really. My old McCulloch ballasts were different. They had a wire that you connected directly to the battery and you had to connect another wire across to the passenger side ballast. I didn't have this wire secured and it ended up on my exhaust manifold one night and got fried and blew out my low beam fuse. The setup I had at the time was a H4 single bulb, not hi/low like they have today, so when the low beam fuse blew, that is when I found you could use your foglights with your parking lights (without having to do any extensive mod - just pull the low beam fuse if you want this look) - however, in order to use the H4's, I just flicked the switch into high beam and the light came back on. This was the only good thing about his ballast. I had thought about connecting it with my H1 bulb, considering the H1 is a single bulb. I could then drive around with my foglights and parking lights on at the same time (after I remove the low beam fuse), except I think I threw the ballasts away a couple years ago, considering I bought replacements that were plug and play.
  17. #457
    Thanks!
  18. #458
    ATLpromotional
    These lights look really nice. You satisfied with your purchase? I might look into buying them in the near future.
  19. #459
    i put also the heads. still needs to be finished and here i would need your help. i have a gap between the head and the bumper, a big one. what to do.
  20. #460
    put the head lights on a while ago sorry for the delay with the pics
Tags for this Thread
