^ really? mine never has, but I opted for the expensive ass greddy one cause i didnt want problems like that. i guess i could see that happening.
What kind of tubular manifold is that? Its not a ebay XSpower one is it?
its totally an ebay one. mine looks just like it!
1996 galant s
Oh yea. One more thing. Youll have to adjust that wastegate actuator arm on that ebay turbo. My GF is running the big 16g from ebay and with her boost controller set to the lowest boost setting its still hitting 20 PSI. Ive yet to adjust it because she doesnt drive the car much and if she does drive it she cant push it past 3k rpm without the stock POS intake pipes blowing off. Were waiting on her to save up for a FMIC and piping. Youll want to look out for that and adjust in small increments.
1996 galant s
bought some parts today
clutch, brake and gas pedal
1g cam angle snesor
coil pack
water pipe
1996 galant s
how the hell do you pop the wires out of the plugs? Driving me nuts cause i pop the white tabs up and nothing. Im about to just cut and solder
1996 galant s
.... try pushing them forward...
ecu swap done. I just needed something smaller to push them out.
1996 galant s
1996 galant s
Dual JDM intarfooler setup FTW!
even says jdm
1996 galant s
JDM = "Just Damn Macho"
Last pic, right next to the dip stick - theres a bolt that proly will snap later on. You needz a mitsu bolt right there
man you should have never cut that bumper up like that......
..... is it a special heat treated proprietary alloy bolt?
no, its not. OEM mitsu turbo bolts are the way they are for a reason. Even down to the special spring washers.
Also just a heads up, the with the extreme heat and vibration of our engines, its not just the welds that fail on thin tubular manifolds. The piping itself can develop cracks and fail. Just make sure your downpipe is secured to the block in the OEM mounting point. there are very few manifolds out there that can handle the weight of a turbo, o2 housing, and downpipe.... as well as the exhaust system swinging around, and the engine torquing against it.
secure the downpipe to the block, and use all polyurethane exhaust hangers(to keep exhaust motion and vibration to a minimum).
Also doesn't hurt to use prothane motor mounts for a million reasons.
