Thread: Galant306m's turbo build
Page 17 of 65 FirstFirst ... 713141516171819202127 ... LastLast
Showing results 321 to 340 of 1287
  1. #321
    ^ really? mine never has, but I opted for the expensive ass greddy one cause i didnt want problems like that. i guess i could see that happening.
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  2. #322
    Quote Originally Posted by kolio View Post
    those can loosen. seen it happen
    the turbo timer is optional, but you just got to take it easy the last 5 min of driving
    as for the clutch and brake pedals i might be able to find some if you need
    please look the ones that i found local are like 100 bux for the pair.
    1996 galant s
  3. #323
    07-20-2003
    Orlando, FL
    3,168
    What kind of tubular manifold is that? Its not a ebay XSpower one is it?
  4. #324
    its totally an ebay one. mine looks just like it!
  5. #325
    Quote Originally Posted by 4-G-rim View Post
    ebay one that i re welded and polished the ports at work. i had it sent though penetration which shows any problems with the welds under a black light with some green die crap lol and then welded the spots that where week or would leak.
    1996 galant s
  6. #326
    Experienced TGC Member
    12-27-2005
    Charleston SC
    1,520
    Quote Originally Posted by Galant306m View Post
    Isnt that like the magnaflux process or some shit like that?
  7. #327
    12-27-2005
    Charleston SC
    1,520
    Oh yea. One more thing. Youll have to adjust that wastegate actuator arm on that ebay turbo. My GF is running the big 16g from ebay and with her boost controller set to the lowest boost setting its still hitting 20 PSI. Ive yet to adjust it because she doesnt drive the car much and if she does drive it she cant push it past 3k rpm without the stock POS intake pipes blowing off. Were waiting on her to save up for a FMIC and piping. Youll want to look out for that and adjust in small increments.
  8. #328
    Quote Originally Posted by Shadow19 View Post
    No magnafluxing is where you take a fine powder and magnetize a piece of steal, the powder will stick to any cracks. Penatrent uses a die that is green and will seep through any bad welds or any voids in the steal.
    1996 galant s
  9. #329
    bought some parts today
    clutch, brake and gas pedal
    1g cam angle snesor
    coil pack
    water pipe
    1996 galant s
  10. #330
    how the hell do you pop the wires out of the plugs? Driving me nuts cause i pop the white tabs up and nothing. Im about to just cut and solder
    1996 galant s
  11. #331
    TGC Regular
    11-14-2007
    Boothwyn,PA
    719
    .... try pushing them forward...
  12. #332
    ecu swap done. I just needed something smaller to push them out.
    1996 galant s
  13. #333
    1996 galant s
  14. #334
    Dual JDM intarfooler setup FTW!
  15. #335
    even says jdm
    1996 galant s
  16. #336
    JDM = "Just Damn Macho"
  17. #337
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    Last pic, right next to the dip stick - theres a bolt that proly will snap later on. You needz a mitsu bolt right there
    Build Thread
  18. #338
    its a grade 8 metric bolt shouldnt have a problem with it.
    1996 galant s
  19. #339
    12-27-2005
    Charleston SC
    1,520
    man you should have never cut that bumper up like that......
  20. #340
    12-17-2004
    Louisville, KY
    4,327
    ..... is it a special heat treated proprietary alloy bolt?
    no, its not. OEM mitsu turbo bolts are the way they are for a reason. Even down to the special spring washers.
    Also just a heads up, the with the extreme heat and vibration of our engines, its not just the welds that fail on thin tubular manifolds. The piping itself can develop cracks and fail. Just make sure your downpipe is secured to the block in the OEM mounting point. there are very few manifolds out there that can handle the weight of a turbo, o2 housing, and downpipe.... as well as the exhaust system swinging around, and the engine torquing against it.
    secure the downpipe to the block, and use all polyurethane exhaust hangers(to keep exhaust motion and vibration to a minimum).
    Also doesn't hurt to use prothane motor mounts for a million reasons.
