Thread: EVR4 Build (56K Beware)
Page 8 of 10 FirstFirst ... 45678910 LastLast
Showing results 141 to 160 of 182
  1. #141
    Oh wow I never posted these here anyways after i got it all together i decided to scrap my extended harness i made earlier and swapped the whole car over to Evolution 6 harness all the electrical in the car now is Evo 6
    Basically the only thing left thats mirage on this car is the trimwork suspension and misc interior parts.
    And this is a video after I retrofitted the tacho motor from the VR4 cluster (Really sad i couldn't use the whole unit especially since i paid close to 180$ for it.)
    http://www.youtube.com/watch?v=6ILI0yUyJy8
    The car is actually mostly together now all the interior is in just waiting for a windshield to be put in and a few other parts.
  2. #142
    08-18-2004
    Charlotte, NC
    1,029
    Sweeeeet!
    1994 GS FYI
    DSM/CSM Manuals
  3. #143
    Experienced TGC Member johnygezony's Avatar
    10-05-2008
    Grand Rapids Michigan
    1,141
    your my hero !
  4. #144
    TGC Regular
    12-14-2006
    New Zealand
    823
    Quote Originally Posted by JDMFTW View Post
    Hmmm.... I wouldn't be revving up to 4-5k rpm when it's not up to running temp yet, you'll probably find that was the cause of the misfire. The ECU retards the timing when it's cold so you don't damage the engine.
    1995 FTO - V6 Mivec 200hp
  5. #145
    Quote Originally Posted by Goku View Post
    It was at optimal temp I had it running for over 2 hours strait only 10 minutes before that video was made.
  6. #146
    TGC Regular
    12-14-2006
    New Zealand
    823
    Really ?
    The temp gauge was showing it was cold, then about a quarter. They are ment to run at about half the temp gauge when warmed up.
    Just seemed a lil' odd was all, must be due to the conversion and the evo temp sensor being different.
  7. #147
    Amazing. Simply Amazing. I dont post much here, but you sir, get my *thumbs up*
  8. #148
    Really ?
    yea the motor in the cluster seems to be abnormally slow.
    it was slowly rising to opt temp the whole time but it was more then optimal lol
    I would never rev a cold engine.
  9. #149
    TGC Regular
    12-14-2006
    New Zealand
    823
    Yea, it seems really weird, I had another look at the vid, and it is moving very slowly, but you can tell by the idle that it is warm.
    Have you had anymore issues with the misfire at all ?
  10. #150
    Nope not since ive changed out my plugs.
  11. #151
    05-03-2007
    Socal/Central Coast
    3,803
    this is simply amazing
    get that damn windshield! haha
  12. #152
    RedGalant's :WUB: :WUB: ICEMAN99TURBO's Avatar
    01-24-2007
    Bad Axe, MI WELCOME 2 HICKVILLE!!
    481
    Awesome read, just got done. You and I sir are going to have to meet up sometime, I would love to shake your hand and see her in person.
  13. #153
    ^ Oh nice you still have a G?
  14. #154
    01-24-2007
    481
    Yep, haven't made the switch yet.
  15. #155
    Quote Originally Posted by ICEMAN99TURBO View Post
    Ill be In Clio and Saginaw a few times during spring/ Summer and fall for some Saginaw meets and Clio for the Project A spec drift events.
    takes a bit out of your drive.
  16. #156
    01-24-2007
    481
    Yea, could do that, but I believe I get down to the Detroit area just as much as Saginaw. :)
  17. #157
    well could always drive out to a drift event :D
  18. #158
    01-24-2007
    481
    Could do that, I have always wanted to go see one....This might be the year. :D
  19. #159
    Plans for 2010
    5 Lug conversion
    twin piston Evo 4 brakes up front
    single piston 2G brakes in back
    Coilovers
    18X9.5 Rota Grids in white
    replace sunroof?
    New black carpet
    reupholster the door inserts with black micro suede
    Evo 8 front and rear seats?
    possibly some new gauges 60mm
    Rear strut tower bar
    ARC intake
    ARC Rad cooling panel
    replace rear pan with brand new pan and frame rails and mod for Exhaust clearance
    Replace my mashed gas tank with a Evo tank
    Find some FG or OEM E5 Skirts and bumper
    Get a Evo trunk
    and a E4 spoiler
    Then paint the damn car
    Not sure if I want to do this yet.
    upgrade to 660cc injectors
    emanage
    Custom intake
    LSD
    aim for 370hp
  20. #160
    TGC Regular
    12-14-2006
    New Zealand
    823
    Whoa, that thing is going to be one sweet ride by the end of 2010 :D
    I thought you were going for brembo calipers in the front though ?
