Well, I thought of that, with the whole melting thing. But the replacement bulbs for the OEM fogs are 55watts, which I assumed would put out enough heat to make a cheap housing melt, but you may have a point.
The problem is when I look on ebay, most of the fog lights I find look so... cheap, and generic. Especially the mounting brackets. Which is one thing I liked about the OEM mounting brackets, they looked secure and sturdy and made them fit nicely.
Another thing that doesn't make much sense to me with the whole relay harness thing (and maybe you can explain this to me Reelax), is... if you look in the picture here, see the #5 plug? I assume that would be the one that would normally plug to the OEM plug to toggle the lights on or off, or in this case an aftermarket toggle switch, but the plug wouldnt match up. So... would the blue wire go to the power source prong on the toggle switch.. and the black to the light switch.. adn then run a seperate wire from the toggle switch ground to a ground source... and then be done?.. Or....?
That's the ONLY thing that confuses me with these damn relay harnesses... I get EVERYTHING else...
With normal fog lights kits without a relay harness, you would hook the power to one prong on the toggle switch.. the wire from the lights to another prong.. and the one prong to the ground... which is what makes me assume this is kind of the same thing?
Am I correct or am I missing something?
Do you have any suggestions for some good after market fog lights with metal housings and glass lenses? I would LOVE some projectors.
T!Bmk~$(KGrHqUH-CEEt66LPVf6BLhpM)tCJQ~~_12.JPG)
