The short answer is, no. The only option is custom turbo (or twin turbo) kits.
may be considered a dumb question. but would it be possible to use the exhaust manifolds, turbos, and all necessary plumbing from the 3000GT TT on our 3.8's since they are in the same 6g- engine family?
Technically you are right, but you actually could use the manifolds from the 3000GT. The 3000GT manifolds are a "squished" port design which is not a direct "mate" for the ports on the 6g72/4/5 series engines in the Galant/Eclipse/Stratus. The side to side measurement of the 3000GT ports is sufficient to match the ports on our heads (72/74/75), but the height is too small (1.5" vs 1.75" IIRC).
With some modification to the 3000GT manifold flange, and piping at the flange you can use these manifolds with no fitment issues.
Eclipse GT 5 spd swapped
Rotor Glow Galant
Daily Galant
OZ Edition Eclipse
interesting too see how close it would be?
ive got boost on my mind.....
this is a bit more feed back than i initially thought id recieve on the topic. Im just simply surprized I havent read about anyone else trying it. Im mainly just throwing ideas out there to see if anything will work for us 9g guys. we cant let the 4g guys have all the fun.
yes i agree i have a 1997 3000gt VR4 and and extra set of manifolds for it. i just may check the fitment on my next day off when im not busy.
