Thread: Post a pic as your car sits now....
Page 839 of 1457 FirstFirst ... 3397397898298358368378388398408418428438498899391339 ... LastLast
Showing results 16,761 to 16,780 of 29136
  1. #16761
    those are his own new wheels. I painted mine green.
    GREEN is the new BLACK
  2. #16762
    11-13-2007
    -OKC-
    3,970
    Nice wheels Galante. Cali, you making another sex mobile huh?
  3. #16763
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Most feel so good to be able to fabricate yourself any bumper or part you want (if you have the mold) whenever you like.
    Cali, Galante, Censee's car look awesome, damn liberal grill is really popular.
    4g64T 5spd
  4. #16764
    Quote Originally Posted by Galante View Post
    damn, thats hot as helll
  5. #16765
    Quote Originally Posted by ASTIG View Post
    yeah i figured that out lol
  6. #16766
    Quote Originally Posted by RAZ_76 View Post
    Hot as hell as usual bud but it's time to work on the undercarriage to match the exterior. Just my two cents.
    yea bro, definitely... hopefully within a year i will have enough money to do a full evo head swap
  7. #16767
    11-13-2007
    -OKC-
    3,970
    Quote Originally Posted by galant350z View Post
    That will be off the hook, with little work and money, you can get entire evo engine, turn it sideways and make the G RWD, you know that right? Do something different, everyone's doing the evo head swaps. You car is hot, keep that streak going, if you just do a head swap, the glory stops since so many have done the same exact thing before you. That's just my opinion, kno wha I mean jelly bean..lol?
  8. #16768
  9. #16769
    side way????
    Have the cams facing the front of the car.
  10. #16770
    11-13-2007
    -OKC-
    3,970
    Quote Originally Posted by skyhigh90210 View Post
    Yes. If Evos can do it, so can you. Just have to tub the firewall and other mods.
  11. #16771
    You are here entirely tooo much!! IVORY_G's Avatar
    07-12-2007
    SoCal
    4,632
    Love all the new pix and mods every1's posting! Awesome! LOL!
    Galant350z I say AWD FTW!
    JDM Zenki Conversion
    Lazy hands make for poverty, but diligent hands bring wealth. (Proverbs 10:4 NIV)
  12. #16772
    08-04-2003
    NY
    4,344
    Alot of the EVO guys doing this are using alot of 1 off parts and sequential gearboxes from either PPG or Hollinger that are really race only type trannies. With that being said, depending on your power goals, you can make the car RWD, pretty much by doing the opposite of what I did on my 8g. You would weld the center diff in the trans, have a solid diff tube made to go from the center diff into the front diff (in the transfer case) you would remove the front diff from the transfer case all together or leave it, although its better out to save weight. Then install aluminum plugs into the holes where the front axles went. Now you would just use the 2g auto rear and custom driveshaft. Essentially it would be the AWD swap but then eliminate the front drive axles and diff. I bet it would hold 400-500whp or so, anything more you would be breaking that diff tube, transfer case or rear diff. This is how the early EVO 8's were converted for drifting.
    99' Galant ES
    4G64/63T
    AEM EMS
  13. #16773
    blue8g
    That. Would. Be. AWESOME!
  14. #16774
    Quote Originally Posted by Cali View Post
    check out the license plate action. :D
    i fixed ur post so the movie would show. great job on the plate motor! i'm glad my idea from last time we saw each other at MOD09 worked out! i tried to figure out how to do it on my car but since i would have to mount it on the bottom of my bumper it would be way too low as i have less ground clearnce allready, i would scarpe the bottom of the plate when it was up and srape the entire plate when it was down; i installed the manual version on my cousin's benz, but his bumper is so short it doesn't hurt ground clearance that bad. dope job, it looks sweet!
  15. #16775
    Quote Originally Posted by Stewi View Post
    You can also run either a GMC type transmission or a r154 supra tranny with a custom bellhousing that will hold plenty of power; tranny is already meant for rwd.
    those r154's transmission hold about 500whp stock and can usually be found for under 500 if you look around
    Cali: Sig 3/28/2011
  16. #16776
    Quote Originally Posted by Reelax View Post
    cool thanks man! yea the only reason i got it is because the lip protect the plate when i bottom out; when i had my lip off i busted the plate frame and had to get another one.
    see you on sat! (hit me up when you're on your way)
    Cali: Sig 3/28/2011
  17. #16777
    05-31-2005
    4,735
    nice.
  18. #16778
    08-04-2003
    NY
    4,344
    yeah but what I was getting at is you wont have to tub anything or do any major cutting or fab to get it in there. There aint no room for that RWD bell housing and trans on an 8g without some SERIOUS work.
    99' Galant ES
    4G64/63T
    AEM EMS
  19. #16779
    01-08-2008
    Levittown NY
    2,786
    For that Supra tranny to work on a RWD Evo would it have to be mounted 90 degrees from what it is now with custom mounts and everything? It looks like the drive shaft is exiting the side of the motor now, or am I looking at it wrong.
  20. #16780
    05-03-2007
    Socal/Central Coast
    3,803
    ^^ the cam gears would be at the front of the car. The drive shaft would come out of the rear of the transmission (the skinny end) and is in line with the engine + transmission assembly. From there it would go to a rear differential to be translated into forward movement. Not sure if that answers your question but that's the best I can do
Tags for this Thread
