Thread: Galant306m's turbo build
Page 46 of 65 FirstFirst ... 3642434445464748495056 ... LastLast
Showing results 901 to 920 of 1287
  1. #901
    12-17-2004
    Louisville, KY
    4,327
    use permatex ultra gray(not red, not black, not blue.... GRAY damnit)
    or go to mitsu and get their oil pan sealant. It will cost you though.
    Also, when you clean all the old rtv off your pan, lay it on a piece of glass(because you know glass is going to be near perfectly flat) if the pan can wobble or doesn't also lay nearly perfectly flat.... then you need a new pan.
    Make sure the pan is clean and free of oil(brake parts cleaner)
    make sure the bolts are clean and free of oil(soak in a cup of brake parts cleaner, or get new bolts)
    make sure the block mounting surface is clean and free of oil, again.... brake parts cleaner.
    The torque spec is very very very low for the oil pan. Its like 16 inch lbs or something(verify this).
    So instead of using a ratchet and cranking down on these till all the silicone comes gushing out,
    try using just a nut driver, or the proper sized(bit) Phillips screwdriver
    also don't forget that the two extra short bolts go under the timing belt. so as not to destroy it and make you cry.
    Oh and a BTW.... don't "let the rtv setup" it doesn't need setup time, in fact this has a negative effect on adhesion.
    lay that bead and go to work. If you have to touch the rtv to smooth it out or something, make sure you have on a clean nitrile glove so your hands don't contaminate the rtv and effect the bond.
  2. #902
    RedGalant's :WUB: :WUB: ICEMAN99TURBO's Avatar
    01-24-2007
    Bad Axe, MI WELCOME 2 HICKVILLE!!
    481
    Great How To info right there.
  3. #903
    Experienced TGC Member
    12-27-2005
    Charleston SC
    1,520
    Without a doubt gray rtv is the best stuff to use. Ive always had issues with the red stuff but never with the gray. I didnt know the short bolts were on the timin side though. Lol.
  4. #904
    12-17-2004
    Louisville, KY
    4,327
    red is high pressure(not all that oil resistant, great for coolant and charge pipe/intake flanges)
    blue is basic(high adhesion under normal low stress conditions.. not all that useful on a car)
    black is high temp(oil resistant, but not ideal for pans or as a case sealant)
    gray is ultra oil resistant(great case sealant)
    copper is very high temp(basically for exhaust flanges only)
    Purple is magic(yes magic does exist, we've known about it for some time)
    unfortunately purple isn't out yet.
    and hondabond is glory.
  5. #905
  6. #906
    From this!
    To this?
    1996 galant s
  7. #907
    12-17-2004
    Louisville, KY
    4,327
    Make sure you cover it with a couple coats of clear if you haven't already.
  8. #908
    For sure i want to do one more coat of the paint and then three coats of the clear before i have the tires put on.
    1996 galant s
  9. #909
    damn mitch. Those wheels look way better!
  10. #910
    12-27-2005
    Charleston SC
    1,520
    No matter how good the wheels look he is still a fag. LOL.. JK JK JK JK.. Dont ban me PLEAAAAAAAAAAAAAAAAAAAAAAAAAASSSSSSSSSSSSSSSSSSEEE EEEEEEEEEEEEEEE! Nice work man. I want to see some inside vids of this beast pushing you to the seat son!
  11. #911
    01-24-2007
    481
    2 Part Mix Clear Mitch, not rattle can!!!!! Or it will not hold up.
  12. #912
    Rims are done tires go on tomorrow ill have pics of how it looks with the new color as soon as i get them back.
    1996 galant s
  13. #913
    1996 galant s
  14. #914
    TGC Regular bsilver23's Avatar
    04-06-2009
    Mequon, Wisconsin
    584
    its all running right??? ik you had that tune done i think :/ ... lets see some more videos!
    Bryan - TGCWI - 6g72 5 speed
    http://www.cardomain.com/ride/3376567
  15. #915
    nope still no tune everything i try and set up falls through scott gray is in china for a month and the other guy that wants to tune it is still in MN for another week.
    1996 galant s
  16. #916
    still no tune MEH looks like she is going to be in the garage till next spring now......
    1996 galant s
  17. #917
    01-24-2007
    481
    Very sad... are you going to come to MOD with Rob?
  18. #918
    probably
    1996 galant s
  19. #919
    Haven't been able to work on this thing now that im working 12's again, but we are just leaving it for the winter now. Going to pull the engine and transmission back out next weekend clean up the engine bay and install a quaife lsd, with forged pistons and hbeam rods, arp head studs, and 272/282 cams then right as spring rolls around we can have it running again and get it tuned.
    1996 galant s
  20. #920
    08-18-2004
    Charlotte, NC
    1,029
    so what cams do you have in it now?
    1994 GS FYI
    DSM/CSM Manuals
