haha, knew it was RPF1s, size, offset?
BETTER TIRE MOAR LOW! ASAP! thx
17x8 40et maybe?
I don't know where else I would put more purple.. lol
and I would LOVE to go lower, but the driveways in Socal are killing me. I already scrape as-is..
Specs: 17x8 +45 on my old 215/50/17
and I forgot to mention, these are actually candy purple so in full sunlight they are almost pink:
with flash:
without flash:
1994 GS FYI
DSM/CSM Manuals
Nice purple rims lol they look great on the car
«Carlos»
Ohh i see yoy mean the metal honey cone pattern. I put the evo maf and chaned all the maf map to the evos. Works great after a few minutes i see the responce right alway. But after a few min idle drops and afr goes rich and lean. I think i need to adjust more of the timing at idle.
I want a lil more purple on mine
«Carlos»
Really do you get a smooth idle or it jumps a little. how about when pedal on WOT. put your foot all the way. i see the PCM is looking for 95 to 99% on the TPS on WOT. i have 7% and is fine at that level but i think is not 100% right. I need to adjust that 100% for tuning reasons. If your tps readings are off it will mess everything in the tune. I will try 12% + more. I found out from factory some tps reads 20% at closed. I was thinking it needs to be at 0% bad idea LOL
how are you adjusting the TPS reading?
EDIT: are you adjusting the function that EvoScan uses to calculate it? currently it is:
TPS = x*100/255
so you're saying to make it:
TPS = x*100/255 + 3
