^^^^Excellent choice. I have these!!
I need front shock mounts and its installing time. U guys thibk it matter if i buy kyb or monroe?
I think he means the plates YOU had hard time pulling apart. LOL!!
Either will be fine, get the less expensive of the two. Will do same thing.
I washed it by hand for the first time since may
New disc, new brake pads, kyb/dr2 and tein s tech loweing springs,. Now im too low to get out of the damn driveway
im thinking of lowering my G what do u guys recomend i get to start i dont want it to low tho. and dont i need springs and shocks? is there a number i can go to the auto part store (i dunno like 223-55 or something)
2001 Galant 2.4 USDMOld ones
2X BMW E34 Blaaackkkk
Isuzu Trooper mountain spec
Worked on shaved valve cover
Solved my overheating issue yesterday by fixing a coolant leak. In conclusion, never replace the coolant tube seal with a regular o-ring. It's just not thick enough to seal the end of the tube. It's $7 well spent.
Nothing better to do when the heat index is over 110 degrees :)
TURBO= in the making.......
