Thread: Post What You Did To Your Car or Bought Today!
Page 120 of 538 FirstFirst ... 2070110116117118119120121122123124130170220 ... LastLast
Showing results 2,381 to 2,400 of 10744
  1. #2381
    Experienced TGC Member Rach3T8G's Avatar
    11-18-2009
    Buffalo, NY
    1,758
    Just got my axle back exhaust :)
    - Chris -
    DRL Delete
    | 6K HIDS | AUX Cord Wired in RF Head Unit | DC Sprots CAI | OBX Longtube Header | Aero Turbine 2540i Muffler
  2. #2382
    Just bought some 3g springs by company called Tenrai. Looks like I might be the first to try on here..when I get the money to install, I'll let you all know how they are. Seems like a lot of quality for the money. http://item.mobileweb.ebay.com/viewi...d=350478795762 I know its a little late now, but these should fit right? It says 00-04 eclipse, but also mentions sebring which has me wondering. But I'm assuming 3g eclipses, 8th galants and sebrings all share same suspension? Also the drop should be slightly lower on my 8thgen because its a galant and v6 right (weight)?
  3. #2383
    Just installed my Hi-beam projectors. Will do the low-beam I'm just waiting for another set of projectors to do the low-beam and CCFL angel eyes.
    TURBO= in the making.......
  4. #2384
    11-18-2009
    Buffalo, NY
    1,758
    Nice!!
    - Chris -
    DRL Delete
  5. #2385
    12-13-2010
    Brooklyn, Maryland
    4,638
    Zobgel, what kind of projectors do you have? Looks nice!
    Sent from my iPhone using Tapatalk fam!
    -Greg
  6. #2386
    Not to direct too much attention to my post above, but if anyone has any answers..much appreciated. Projectors do look good zogbel
  7. #2387
    Experienced TGC Member n3oAcid24's Avatar
    04-13-2005
    Chicago
    1,945
    just got my fuel lid in today. now i have to paint it and install it... hopefully soon!
    n3oAcid24 = 01' Galant I4
  8. #2388
    Experienced TGC Member 99galantES's Avatar
    04-08-2010
    Springfield, Mass
    1,225
    Quote Originally Posted by 8thLS6 View Post
    they should fit all suspension are the same between the 3g and 8g now about the drop idk i have 3g ksport lowering springs on my car
    «Carlos»
  9. #2389
    Got my stuff the I had ordered from Hong Kong... An LED mitsu logo that Im going to have on the trunk and bought a pod with three gauges... Volt, Oil pressure and water temp... the water temp I bought as an extra to really see if the one that mitsubishi has provided in the cluster panel really is accurate...
    Thomas R aka Valpen
    CEO & Eventmanager
    Mitsubishi Club Sweden
    Former New yorker....
    94-10 60th Ave
    113 73 Elmhurst, NY
    School PS13 - then moved to Europe
  10. #2390
    Quote Originally Posted by 99galantES View Post
    That's cool. Really if it drops atleast what it claims to do so on an eclipse ill be happy, if it drops more, then that's icing on the cake. My biggest concern was fitment. Also it won't be possible to get the fronts confused with the rear springs, because they'll be the same diameter as stock springs just shorter right?
  11. #2391
    04-08-2010
    Springfield, Mass
    1,225
    that is correct i feels to me like the drop in the front between the 3g and 8g isnt the same i could be wrong
    «Carlos»
  12. #2392
    05-14-2010
    Coachella, CA
    5,954
    You can tell the difference right away between front and rear. The only thing you should worry about is spring rates, A few things can happen, either everything will work out fine, or the ride will be a bit stiffer than on a eclipse, or the ride will be bouncier than on a n eclipse. Which is why unless it's coil-overs you want to stick with suspension parts designed for you cars dimensions and weight.
  13. #2393
    The front and rear are completely different from each other. it should be an obvious difference when you see them.
  14. #2394
    Alright thanks fellas, I'll give my opinion on them when they get installed.
  15. #2395
    05-14-2010
    Coachella, CA
    5,954
    The front springs are the Ginormous ones that belong on an F350.
  16. #2396
    Got my rear window visor and accord mirrors colormatched steel grey to my car today. Will install this weekend
  17. #2397
    04-08-2010
    Springfield, Mass
    1,225
    Took off the wheels and back on steelies for now car looks weird and lower
    «Carlos»
  18. #2398
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Received new front rotors since mine are warped, and new akebono ceramic pads, still waiting for my custom shift boot, usps received it on July 7 I'm still waiting, tracking shows only the date of acceptance ugh....
    question: if usps screwed up would you guys make a paypal dispute with the seller to make him deal with usps and find out what happened? Or would you just leave it there, the boot was $20 so it isn't that much (but still half tank of gas).
    Opinions
    4g64T 5spd
  19. #2399
    Quote Originally Posted by wetamup2k3g View Post
    Thanks bro. Its from a Mercury Milan.
  20. #2400
    12-13-2010
    Brooklyn, Maryland
    4,638
    Mercury Milan eh? Cool stuff!
    In other news, I have a new toy (well, my wife does, but I'll be playing with it) in the stable, and I'm keeping it in the Mitsu family:
    2002 Diamante LX fully loaded, runs good and silent, 174,000 miles, for $1800. I'll have it Tuesday, I spent only a little time with it today.
    -Greg
