Thread: Matt's 03 Galant ES build thread
Page 3 of 5 FirstFirst 12345 LastLast
Showing results 41 to 60 of 87
  1. #41
    Quote Originally Posted by tamim13 View Post
    a bent wheel will cause vibration in the steering at higher speeds, when it's not too noticeable. Put the bent one in the back and see if it goes away. If it's still there, it could be your CV joints as well. Check if the CV bellows are hard or soft to the touch and if the grease is leaking.
    Well there is this rubber bushing connected to the lower control arm that had grease on it but it looks like its coming out. I don't know if you know what im talking a bout ill try to get a picture but don't have my camera right now.
  2. #42
    UPDATE:
    2nd Gen tails are in (after 6 hours and 3 blown fuses) as well as red LED's in the gauge cluster. As well as a full 2.5 inch exhaust from the cat all the way back, no muffler. Pics coming soon
  3. #43
  4. #44
    Update,
    The G is parked right now with a bad fuel pump but Im on my way to FT. Benning right now for four months and hopefully my friend will fix her while im gone. When I get back its on. So Ill be back on TGC then.
  5. #45
    02-17-2011
    i live in sunny florida
    1,240
    i have a buddy in ftbenning right now going threw bootcamp
  6. #46
    Quote Originally Posted by finald8ta View Post
    wats his name and unit?
  7. #47
    Update
    So, I returned from training about 2 weeks ago and In that time the g has gone through some serious work. Mainly, I got her completely resprayed and installed Megan coilovers. Unfortunately this is the only decent photo i have,
  8. #48
    12-13-2010
    Brooklyn, Maryland
    4,638
    Makes me miss my gray one, looking good!
    -Greg
  9. #49
    02-17-2011
    1,240
    Quote Originally Posted by Rodriguez View Post
    Patrick matuzac don't kno what unit, iirc he went to airborne after bootcamp, I think, and welcome back
    HTC EVO 4G
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  10. #50
    Senior TGC Member Skyforger's Avatar
    05-05-2011
    Medford/Long Island, NY
    2,135
    Yes!
    Looks good, d00d.
    -Chris-
    2003 Mitsubishi Galant ES 2.4L SOHC: "Octavia"
    2005 Honda Accord EX-L Coupe 2.4L DOHC
    Quote Originally Posted by XxGiRLaNT06xX View Post
    From the looks of the girl, her face isnt that great.. nothing a paper bag couldnt fix... amirite?
  11. #51
    Some trouble afoot, help greatly appreciated.
    Alright so so some bad shit went down with the car recently. I had a bit of an accident (someone cut me off and I slammed into a curb at 25-30mph). Anyway, so far as i can tell all that happened is my camber and caster is off (car pulls right really badly), I cant see that anything is bent. I also warped a rotor. So I ordered some drilled and slotted ones for the front and ceramic pads. Also ever since I had the timing belt done my car has had a lingering odor of fuel after start up and after shut off. I cant tell if its a leak and if so where? Any suggestions? other than that the new megan coilovers are amazing. I dont know how I ever drove without them.
  12. #52
    11-29-2009
    Chadds Ford, PA
    2,768
    I would say check the return line
  13. #53
    I found the leak. Its a brass or copper connection on the fuel line that starts on the drivers side of the fuel rail. maybe 4-6 inches down the line close to the firewall. It seems pretty serious, like a steady drip when the cars idling. Im kinda worried, definitely dont wanna drive it. Anyone else experience this issue?
  14. #54
    11-29-2009
    Chadds Ford, PA
    2,768
    I dont have my car in front of me but I believe somewhere you can remove and replace that whole line
  15. #55
    this is the part in question.
  16. #56
    11-29-2009
    Chadds Ford, PA
    2,768
    Yeah, if there is a 4 banger in the yard when I go I can get you one, If not I can get you the part # for it.
  17. #57
    I've seen those wheels from time to time while browsing ebay, and I always wondered how they would look on an 8g. From the looks of it real good, especially with the color of your car. Nice!
  18. #58
    Update
    So ive still got the fuel leak but Ive been working in the meantime. I installed new slotted and drilled rotors, ceramic pads and removed the calipers painted them and bled the whole brake system. Stops pretty well now, a little too well for a car without ABS lol. But its all good.
    The busted ass rotor from the accident and the new ones.
  19. #59
    Experienced TGC Member 02redgalant's Avatar
    02-07-2007
    ORLANDO
    1,599
    mann i miss MIA...looks nice man
  20. #60
    05-05-2011
    2,135
    G's looking good. But that rotor...metal to metal much? lol
    -Chris-
