Thread: Post What You Did To Your Car or Bought Today!
Page 175 of 538 FirstFirst ... 75125165171172173174175176177178179185225275 ... LastLast
Showing results 3,481 to 3,500 of 10744
  1. #3481
    Ah not really the rear brembos fit with most regular aftermarket rims in the back ...no need to roll rear fenders....and the fronts where it will definately poke because most people just go wit spacers ......well I myself have never had the front rub...and I have a tein set springs/kyb struts
    Can you size down your sig please? Thanks, Admin :)
  2. #3482
    Quote Originally Posted by cleazy123 View Post
    Well seeing those pictures it seems like it would rub.
  3. #3483
    Calipers definately are bigger than standard 1 piston rears bu nowhere near as big as the fronts they are the main concern Greg
  4. #3484
    From that picture of the black rim that's an 8.5 in Tim but from the inside there is a lot of room....sorry to mislead u but honestly I feel galants deserve a much bigger tire than factory 195 lol. So wit that being said I would roll fenders anyway especially prior to a paint job. But I don't think Greg has a drop yet so almost certain they won't rub and they'll definately fit with his current rims but the fronts.....that might be a problem
  5. #3485
    12-13-2010
    Brooklyn, Maryland
    4,638
    I'm thinking the Brembos might fit no problem, I'm running 19mm spacers, it looks like a lot of room. And I am rubbing slightly; if I alter my driving it's no big deal, it won't rub if I'm careful, but if I drop it rolling is a must. I'm gonna roll anyway, no sense in paying $500 for tires and then destroy them by rubbing on the fender.
    Sent from my iPhone using Tapatalk fam!
    -Greg
  6. #3486
    Hey Greg what's the reasoning for the 19mm spacers?
  7. #3487
    Something about the bore of the rims was off so he needed spacers to compensate for it.
  8. #3488
    12-13-2010
    Brooklyn, Maryland
    4,638
    The wheels have a 56.1mm centerbore, the car has a 67.1mm hub bore. I had a bolt-on spacer made that can fit this application, however the smallest size they could make them in is 19mm, so that's what I got. My guess is, they needed that much material for the hex nuts to safely fit on and clear the mating surface. I could've went with a spacer with the same bore specs that wasn't bolt on, but I would've needed longer lug nut studs and I didn't feel like changing out all the studs on the car.
    Pic of the spacers:
    -Greg
  9. #3489
    Tru..Tru....
  10. #3490
    04-29-2009
    Holyoke,Massachusettes
    3,600
    New windshield
    FreakyDeaky
    2kG 6g72/74 5 speed
  11. #3491
    TGC Regular Guzm4n's Avatar
    02-02-2011
    Des Moines, IA
    736
    These aren't going to go on until my car gets repainted, should have the struts and shocks by then hopefully.
  12. #3492
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Did the valve cover gasket today, since I have some oil leaks and that was one, next passenger axle oil seal, and check if installed oil pressure switch is leaking :(
    4g64T 5spd
  13. #3493
    02-17-2011
    i live in sunny florida
    1,240
    Sound deaden the floor and put a newer carpet in, also installed grey interior, only thing that didn't make it was the headliner, I'm going to have to fix it, it was starting to sag. I'll take pics of it all installed tomarrow, once I clean up the center console, it might get replaced with a grey one to tie it all together, maybe u guys can be the judge of that, also ill be replacing the window switch covers to grey once I get them from a member
    HTC EVO 4G
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  14. #3494
    TGC Regular Redhaze's Avatar
    10-02-2010
    North Carolina
    774
    Quote Originally Posted by finald8ta View Post
    HTC EVO 4G
    What sound Deadener did you use?
    -Dirty South-
    They See Me Rollin They Hating -Riding Dirty-
    It dont smell or anything so F it.
  15. #3495
    Threw on the Greddy counterweight shift knob. that thing feels amazing!
  16. #3496
    02-17-2011
    1,240
    Quote Originally Posted by Redhaze View Post
    nothing special, peel n seal, I have sound deadner on my doors from and audio place where I got my front speakers and its the same stuff
    HTC EVO 4G
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  17. #3497
    You are here entirely tooo much!! 99 galant's Avatar
    07-19-2007
    Connecticut
    3,987
    keep that interior transformation going man!
  18. #3498
    Possibly buying a sibling for it. This one for the girlfriend if it is as nice as I'm hoping.
  19. #3499
    11-29-2009
    Chadds Ford, PA
    2,768
  20. #3500
    New project.
    TURBO= in the making.......
