Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 29 of 53 FirstFirst ... 1925262728293031323339 ... LastLast
Showing results 561 to 580 of 1043
  1. #561
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    Nah man, the difference is too big. You need the evo rotor for the swap
    Build Thread
  2. #562
    Yeah that is a big difference,i was just curious to see if you absolutely needed the 5 lug swap for it.The 6g rotors and the 2g dual piston caliper set up looks like what i would be doing then.That is just bolt on from what i was told to do that.
  3. #563
    Quote Originally Posted by galantlvr34 View Post
    Ya to do the 4 piston swap you need evo rotors 320mm or 99 3000GT vr-4 rotors 314mm
    All dual piston brakes from a 2G/3G/8G are 276mm
    Stock galant singles are 257mm
    6G VR-4 rotors are 265mm
    Quote Originally Posted by polishmafia
    You want real respect from those fools? Don't race him. Tell him racing is a sport left to young boys who are still waiting for their balls to drop. Then while he's out racing, fuck his girlfriend in the ass, take pics, and leave them on his car while hes at school.
  4. #564
    08-18-2004
    Charlotte, NC
    1,029
    I wonder what the size are for the WorldSpec 7G dual piston 4 lug rotors
    1994 GS FYI
    DSM/CSM Manuals
  5. #565
    09-20-2007
    Sea Isle city, NJ
    4,098
    I dont see why they'd have 2 different size rotors with the dual piston caliper. I mean 3000gt SL, some 1g GSX, all 2g GSX, 6gvr4, 1g and 2g Diamante have the same dual piston caliper. They should all have 275mm rotors
    Build Thread
  6. #566
    look it up. any place that sells rotors says it. i also have a set too. when my cuz brings me my axles i will tell him to bring them as well. but they were slightly smaller if memory serves me right
  7. #567
    online it says that size. but i understand what you mean. it makes no sense.
    let me measure them when i get a chance
  8. #568
    09-20-2007
    Sea Isle city, NJ
    4,098
    Finally done. Today was a very stressful day. I went to two shops that didnt want to do an alignment because my car had modified suspension. Finally got pepboys to do it, and they did it only because my friend was working, so he took care of it.
    Build Thread
  9. #569
  10. #570
    12-17-2004
    Louisville, KY
    4,327
    I'm still not sure why you need that much toe adjustment. Mine was set perfectly to OEM spec using the factory control arms and prothane bushings.
    But anyways.... Having a proper alignment is where its at haha isn't it?
    Omg once I finally got everything to spec the car became sooo much more predictable, and I'll swear till the end that it improved the ride quality dramatically.
    Keep it coming bro!
  11. #571
    12-27-2005
    Charleston SC
    1,520
    Keep it coming bro!
    Idiots around here dont know anything about making the alignment meet the specs... Ive fought alignment issues for the past 3 years and ive been screwed every single time.... I give up so now i have a steering wheel that isnt straight, a car that pulls with the slightest crown on the road, and camber thats almost 2 degrees different on the rear from one side to the other.... Tell me that aint some shit. Ive bitched, argued and damn near jumped over counters but it doesnt help.
  12. #572
    09-20-2007
    Sea Isle city, NJ
    4,098
    When I lived in PA, I always went to the Sears Center and they did a wonderful job dialing the suspension - camber, toe and caster. I always paid the $69.99 for the whole thing and it never took more than 45 min.
    One of the shops quoted $300-500 for an alignment, because I could have taken them 4-6 hrs to dial the camber. I was like HELL NO and I left!!
    Build Thread
  13. #573
    09-20-2007
    Sea Isle city, NJ
    4,098
    Quote Originally Posted by Shadow19 View Post
    Dude, if you have camber kits installed and the shop dont want to do camber, Ill tell you the easiest way to do it.
    Get a leveler, put it vertically across the wheel/tire and try to get it right in the middle with the camber kit. It will take you a few tries, but its worth the hassle. Then just take it to the shop and get the usual toe/caster alignment.
    Build Thread
  14. #574
    09-20-2007
    Sea Isle city, NJ
    4,098
    Well, that was the only not-upgraded part of the rear suspension and I hated the stamped steel arms. I had to grind off a good chunk of the OEM arm because of the 22mm addco sway bar.
    Build Thread
  15. #575
    09-20-2007
    Sea Isle city, NJ
    4,098
    I guess I should have multiple-quoted on this one.....ha haha
    Build Thread
  16. #576
    12-27-2005
    Charleston SC
    1,520
    Sears did do a good job with my gf's 2g, but i was limited to places i could go due to the body kit, that i no longer have.. I dont put but MAYBE 2500 miles on the car a year so its not like ive been driving daily on a fucked up setup. Im going to go to sears when i get the funds, but ive just held off till the time i can do my sway bar swap and prothane bushings to be honest. The car isnt eating tires or anything so i just deal with it.
  17. #577
    09-20-2007
    Sea Isle city, NJ
    4,098
    This project is officially over. Time to move on!!
    Build Thread
  18. #578
    Experienced TGC Member Rach3T8G's Avatar
    11-18-2009
    Buffalo, NY
    1,758
    What happened??
    - Chris -
    DRL Delete
    | 6K HIDS | AUX Cord Wired in RF Head Unit | DC Sprots CAI | OBX Longtube Header | Aero Turbine 2540i Muffler
  19. #579
    Experienced TGC Member carl3g's Avatar
    03-16-2010
    Maplewood, NJ
    1,290
    Im guessing you bought a new car or planning on a new one. Am I close?
  20. #580
    Quote Originally Posted by carl3g View Post
    Yeah you are close
