Now you need this to go along with the front roll mount :)
those would be prothanes, ill be installing me rear this Saturday, the rear is different because its from a manual 3g, the auto is a lot bigger in the middle and the inserts won't work,
^^^ x2. U need to use a manual eclipse rear mount to uses the pro inserts.
There are 3 different rear mounts.
Galant
A/t eclipse
M/t eclipse.
I got the hardware from silvertune on c3g. I think he's sending the kits out for around $15 shipped. info should be on the last page of his members ride thread.
^I suppose another option is to just get a thicker bolt @ the local hardware store
^ thats what i did if i remember correctly it was a 5/8th bolt that fit the best. you have to drill out the the black bracket that mounts to the transmission also
the sleeve is 7/8" X 1/2" X 2.60"L from the info on prothane's site
you mean the bolt head was 5/8"? I haven't looked at the mount in awhile but it scares me to remove that much material.
Actually now that I think about it, it's not that much material at all.
I think MRG mentioned something about how loose of a fit it was and started this little tut...
https://www.thegalantcenter.org/showthread.php?t=47912
M/T rear mount part # MR272202
Just incase someone needs it. Really surprised to see its made here in the US
sob I payed 50$ for mine
I used that part number on eBay and found it for 25$
