Thread: Axles stuck in hubs...any ideas?
Page 2 of 2 FirstFirst 12
Showing results 21 to 29 of 29
  1. #21
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    If something is to be damaged, Id rather buy just one thing - either axles or hubs
    Build Thread
  2. #22
    Personally I would replace the hubs anyhow since that's also the bearing and has good now's what for miles
  3. #23
    Also when heating it up the trick is to apply the heat to the hub only so that it only expands they are dissimilar metals like our motors the block and head expanded at different rates if you heat the axle it may expand and lock itself in even thighter.
  4. #24
    11-13-2007
    -OKC-
    3,970
    I recommend wearing hearing protection when beating the shit out of things with a hammer. Unlike that guy.
    Wait what, whats that, huh?
  5. #25
    12-17-2004
    Louisville, KY
    4,327
    Quote Originally Posted by troubled4g64t View Post
    I disagree completely. The key is breaking the bond. If you heat the axle and let it cool the expansion will break the rust. If you heat the hub, you risk damaging the bearing or the lubricant inside of it.
  6. #26
    09-20-2007
    Sea Isle city, NJ
    4,098
    Both axles are out, but I need two axles and a hub. If someone is going to the yard I will appreciate it if you looked for AWD 2g and see what it has.
    Build Thread
  7. #27
    What method did you use
    Me I'm a lil of both
  8. #28
    09-20-2007
    Sea Isle city, NJ
    4,098
    beating the shit out of it with a sledge hammer method.....after everything else failed
    Build Thread
  9. #29
    Dead blow works every time.. Lube those suckers up with grease when you put it back together it keeps the moisture out and shouldn't happen again..
