Thread: General 8G Question Thread
Page 14 of 33 FirstFirst ... 410111213141516171824 ... LastLast
Showing results 261 to 280 of 650
  1. #261
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    Quote Originally Posted by wetamup2k3g View Post
    This! For stuck bolts, I find that continual blasting with the impact coupled with spraying PB Blaster, they slowly come out with minimal damage to the threads (if dirty or damaged threads are what is causing the bolt to be stuck). This is for stuck bolts in general, I've never done the actual crank pulley bolt myself, but I encounter stuck bolts all day at work.
    Disclaimer: I use either a Snap-on 3/8", a Snap-on 1/2", an Ingersol-Rand 1/2" or Ingersol-Rand 3/4" air impacts with a 100psi supply, top quality joints!
    thanks guys
    I'm going to try PB blaster with a freakishly long cheater bar (I had to give back the impact and air supply to the buddy I'm borrowed it from) before I throw in the towel and farm this out to my high school autoshop teacher to try to figure out
  2. #262
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    IIRC when I did the timing belt on my I4 the FSM said to fix a breaker bar somewhere and crank the engine a little without turning it on (as somebody said disconnect the crank sensor), and it came loose easily.
    4g64T 5spd
  3. #263
    Does anyone know a good website to buy a used 4g64 motor? I have looked at some but im kind of afraid to hand over a certain amount of money on the internet. Has anyone ever hear of automotix.com or japanengine.com
  4. #264
    Quote Originally Posted by Smokey92 View Post
    Car-parts.com look for close by junkyards and go get one.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  5. #265
    Thanks but I have already tried majority of all junk yards in my area and only 3 have an engine that i need and out of those three one of them has been sitting out in the rain. Another yard has more than one motor but does not know the actual miles on it, they say that they got it from the insurance company. And last but not least the third yard has one motor with 148,000 miles for $650 plus tax. One more thing each yard wants around the same price.
  6. #266
    05-14-2010
    Coachella, CA
    5,954
    Picked up a rear disc swap yesterday, want to piece everything together so I can tackle it without having to stop to hunt down parts. I was reading over the 'How to' and the Metering/Proportioning Valve swap.
    Can I use the existing rear soft lines for the swap or buy new rear hoses that will fit the caliper?
    I cut them from the car I took them from at the yard, I was thinking about saving them but they looked dry and had stress cracks in them.
  7. #267
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    It goes - hard line - soft line and hard line again. If you can get the second hard line off the drum cylinder w/o damaging it you can reuse it. If you damage it then you can always get $3 hard line from the parts store with M10x1.0 inverted flare fitting on each side
    Build Thread
  8. #268
    05-14-2010
    Coachella, CA
    5,954
    Doesn't the rear soft line just go into the caliper?
  9. #269
    09-20-2007
    Sea Isle city, NJ
    4,098
    The stock drum soft line ends with female fitting, the caliper has female thread too.
    The stock disc soft line has male fitting
    Build Thread
  10. #270
    05-14-2010
    Coachella, CA
    5,954
    So you are saying to use the last male hard line into the caliper?
    Would it be easier/cleaner to just buy V6 soft lines?
  11. #271
    09-20-2007
    Sea Isle city, NJ
    4,098
    Or that. Just be careful what you order, some v6s came with drums.
    Build Thread
  12. #272
    05-14-2010
    Coachella, CA
    5,954
    I will keep it in mind, many thanks!
  13. #273
    no USDM 8g v6 ever came with drums.
  14. #274
    Has anyone ever bought used parts or motors from LKQ?
  15. #275
    05-14-2010
    Coachella, CA
    5,954
    I you mean a yard, then yes. My buddy got a transmission for his G, did a flush runs perfect.
  16. #276
    THanks for the input but I ended up buying a motor from another company in California.
  17. #277
    TGC Regular Guzm4n's Avatar
    02-02-2011
    Des Moines, IA
    736
    My dashboard is cracked and I was going to replace it with one that's in really good condition. My current dash has the speaker in the middle, but my extra one doesn't and I was wondering if I make a hole in the extra one for the speaker, will it crack later on? Right now I have the speaker disconnected since I need to replace it, I was thinking of replacing the speaker when I switch out my dash.
  18. #278
    05-14-2010
    Coachella, CA
    5,954
    Use a hole saw of the correct size.
  19. #279
    02-02-2011
    Des Moines, IA
    736
    Thanks oak, I'll try that.
  20. #280
    05-14-2010
    Coachella, CA
    5,954
    ^ I've seen them as big as 7 inches in diameter, obviously you'll need a drill.
