Thread: Galantman03's 8G Build
Page 34 of 70 FirstFirst ... 2430313233343536373844 ... LastLast
Showing results 661 to 680 of 1392
  1. #661
    11-29-2009
    Chadds Ford, PA
    2,768
  2. #662
    six to midnight!
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  3. #663
    Wacha mean Willis?!!
    Quote Originally Posted by Ivory8g View Post
    six to midnight!
    You wouldn't have known what that means if you didn't watch that movie!
  4. #664
    Your only going to use 1 -10?
  5. #665
    Look again, there is 2.
    Ok 2 questions, since i trust people here.
    Is this correct? On evo holes. And which way, clock wise or counter clock wise
    Advance and retard
  6. #666
    02-17-2011
    i live in sunny florida
    1,240
    sweet
  7. #667
    Quote Originally Posted by finald8ta View Post
    ever thought about looking at the timing setup on the evo to get an idea on where it should be for the timing marks?
    granted they are adjustable cam gears, im sure someone will give you a better answer then me,
    this is abit out of my league, and still learning
    I thought about that, but alas i don't have/can't find my stock evo ones lol
  8. #668
    USDM mitsu engines rotate clockwise.
  9. #669
  10. #670
    Yes?
    Spinning the Cams:
    clockwise = advance
    counter clockwise = retard
  11. #671
    TGC Regular bgood12's Avatar
    07-17-2009
    From Dallas, Texas in Topeka KS
    554
    if this is 64 with evo head then u line the marks up to the middle and then ofset I think intake cam a half tooth to top. Its somewhere I read this but I can't remember where, confirm first. Try evom serach.
  12. #672
    Evom sucks for info on the 64/63 head timing info, and its fricking confusing. I know a couple people have fidanza gears here, but idk if they have the 64 block. I think xd does...
  13. #673
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Quote Originally Posted by Galantman03 View Post
    When I was doing some research I found this AMS pdf that had some pics of the timing although it says its for a "AMS Spec deck height":
    And its captioned:
    Setting up the cam timing is a little different. The timing marks on the cam gears need to be moved counter clockwise half a tooth.
    Because the cams are pulled slightly forward due to the custom deck height, you will need to retard the cams 3.75 degrees to get them to "factory" position.
    Don't know if this helps, I'd wait for stewi to answer.
    4g64T 5spd
  14. #674
    When we research with/for our fellow G-men we learn as a community
    Great build
    Me I'm a lil of both
  15. #675
    Well in the time tgc got upgraded. Just waiting on the clutch
  16. #676
    ^let me know when you want to drop it off at my house! lol thats awesome to see it in one piece again
  17. #677
    Well it needs to be baby sat when i leave.... Lol
    Alright, I'm going to redo the power steering connections. What size adapters do i need For the power steering metric to an adapters?
  18. #678
    And the reason why i switched to all evo pulleys?
  19. #679
    11-29-2009
    Chadds Ford, PA
    2,768
    I had considered that. But with the balance work from the pulley to the clutch it shouldnt be needed I thought?
  20. #680
    Well here's my thought. Factory balancer is tuned to the factory internals. I don't have factory internals, i have forged internals, therefore you spend money on a nice motor, cheap insurance.
Tags for this Thread
