Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 37 of 53 FirstFirst ... 2733343536373839404147 ... LastLast
Showing results 721 to 740 of 1043
  1. #721
    You are here entirely tooo much!! IVORY_G's Avatar
    07-12-2007
    SoCal
    4,632
    Nice parts, cant wait to see the finished product!
    JDM Zenki Conversion
    Lazy hands make for poverty, but diligent hands bring wealth. (Proverbs 10:4 NIV)
  2. #722
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    I see Phizz being close to finishing his AWD swap I decided to update this thread. I have done much work to the Galant by sitting on the sofa and watching TV.
    Build Thread
  3. #723
    09-20-2007
    Sea Isle city, NJ
    4,098
    Well finally I did work on the car.
    Yesterday, the pedals got installed and new master clutch cylinder. Took care of the driveshaft misalignment issue - it now sits on straight. I have the carpet waiting here and bunch of other small things to go in the car.
    My next project is to put the mock up block back in, install a DOHC head on it and do the wiring harness.
    Build Thread
  4. #724
    Pics
    Me I'm a lil of both
  5. #725
    09-20-2007
    Sea Isle city, NJ
    4,098
    I just found some good shape rear bench seats. It came off a S model which didnt come with arm rest and the metal backing. The seats are very light.
    The engine bay hasnt changed although Im going to pick up an engine tomorrow. I found a 97 engine with 95k on it for $210, not bad at all. It will get Eagle rods and Evo 10 pistons.
    Also found some Eclipse gr2s with stock springs. The assembly is already 1 inch shorter and it should go lower under the weight of the car. Now I need to find some rear shocks and springs.
    Build Thread
  6. #726
    08-13-2008
    Waterbury, CT
    3,331
    how are you going to do that setup? evo x pistons went to a 23mm pin correct? boring rods is around 200 bucks. also, the stock bore size is 86mm for the 10s so did you get 20 over pistons which are 86.5 stock for our bore? interesting concept as they arent forged either
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  7. #727
    09-20-2007
    Sea Isle city, NJ
    4,098
    i got quoted $200 for the wrist pin bore fix and balancing the assembly. You got the sizing right - they have to be .5mm over and they go for 67 bucks each. It doesnt matter they are not forged, the car will be daily driven at 20 psi on hx35. Nothing these pistons can handle. But hey if i get a deal on forged pistons I most def will use forged pistons
    Build Thread
  8. #728
    08-13-2008
    Waterbury, CT
    3,331
    well all that means is later on you can use evo x forged pistons. interesting innovative thought. look forward to seeing it, i also like how the evo xs use full floating pistons.
    2014 Lancer Evo GSR
  9. #729
    09-20-2007
    Sea Isle city, NJ
    4,098
    I got the motor today, and I had a bit of a problem in the yard. Since it was a SOHC motor and I dont need another SOHC heaad, I went and asked if they would sell me just the block for less. No good - block or entire engine for $200. Well I went and found an 1g and pulled the head off it, slapped it on the block and done deal.
    Started taking the engine apart - balance shaft's teeth were shredded and the water pump was shot. Just on time for the 95k mile and proly very little maintenance.
    And A few pics from when i was getting the car ready for MOD 2012 that I missed.
    Freshly detailed:
    Build Thread
  10. #730
    Re: MKO's AWD/Turbo/DOHC/5 Speed Project
    I thought we were supposed to go get that engine together. U never told me when!!
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  11. #731
    11-29-2009
    Chadds Ford, PA
    2,768
    Whats the benefit of the EVO x pistons besides price?
  12. #732
    09-20-2007
    Sea Isle city, NJ
    4,098
    I knew you re busy during the weekend and this is when i have off, so it was kind of...i didnt wanna bother you.
    But you can tell me when you're available cuz I have stuff from the new engine that need powder.
    Build Thread
  13. #733
    09-20-2007
    Sea Isle city, NJ
    4,098
    they can handle 20-25 psi of boost. I just dont know if they come with wrist pins or not. If they dont then I might just get forged pistons again
    Build Thread
  14. #734
    11-29-2009
    Chadds Ford, PA
    2,768
    Ah makes sense
  15. #735
    [QUOTE=mko;768682]I got the motor today, and I had a bit of a problem in the yard. Since it was a SOHC motor and I dont need another SOHC heaad, I went and asked if they would sell me just the block for less. No good - block or entire engine for $200. Well I went and found an 1g and pulled the head off it, slapped it on the block and done deal.
    funny,you just got to play their game and it looks like you scored big on that one.
  16. #736
    I'm not that busy hit me up and let me know when u wanna come by
    '95 Kawasaki ZX9R
  17. #737
    08-18-2004
    Charlotte, NC
    1,029
    New bumper huh?
    1994 GS FYI
    DSM/CSM Manuals
  18. #738
    damn look at you man! car looks sick!
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  19. #739
    09-20-2007
    Sea Isle city, NJ
    4,098
    Quote Originally Posted by mysticj View Post
    New bumper huh?
    Not really, Ive had it for over 2 years now. You need more TGC time.
    Quote Originally Posted by Ivory8g View Post
    Thanks bro. Good to see 8g members reading my thread.
    Build Thread
  20. #740
    did you ever come up with a solution for the side skirt caps? does a lot of debris go in the gap?
    Quote Originally Posted by polishmafia
    You want real respect from those fools? Don't race him. Tell him racing is a sport left to young boys who are still waiting for their balls to drop. Then while he's out racing, fuck his girlfriend in the ass, take pics, and leave them on his car while hes at school.
