Thread: Greddy's build thread!! Better late than never!
Page 34 of 53 FirstFirst ... 2430313233343536373844 ... LastLast
Showing results 661 to 680 of 1056
  1. #661
    *bookmarks link*
    O_o Jigz you should rape a stock X. Ivory was pulling evo 8's and 9's with bolt ons and tunes while she was untuned. Dont wanna thread jack but im curious. do you know what timing you are running at WOT?
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  2. #662
    No idea. Devin is pretty hush with his tunes. Though one thing I forgot to mention these were all highway runs in 5th gear. I was pulling them without even downshifting. I have yet to play with an EVO X in a gear lower than 4th.
    On the way home from factory MOD I was playing with a grey evo x on the expressway. Left it in fourth gear, and I was running from him for a good 5 mins until he blew past me (ran out of gear). A couple of days later, I get a PM on JDMChicago by the driver asking me what was done to BabyG. He was astonished when I said "a little over 200whp" because apparently he's got a lot of mods and he was legit working to catch me. He then proceeded to tell me his car made 500whp on A-specs dyno and a little research of his username confirmed it.
    Now, there is no way I am making any amount of power to even keep up with is X but the fact that he had to WORK to catch BabyG was enough satisfaction for me.
    Sorry for the Jack Martin, but this ^^^ is what you have to look forward to! =)
    Jigz-TGCIL Sosick Motorsports
  3. #663
    OK word thats much better. I was about to say from a roll on the street you should be demolishing. *thumbs up* :)
  4. #664
    I"m looking forward to the power, I'm sure I'll figure the speedo out soon enough, now all the evos I pass in the corners won't fly past me on the straights :)
  5. #665
    any suggestions on the speedo though??? other than doublechecking my wiring?
  6. #666
    Thats all I got on that one. The speedo should work without bypassing anything or changing anything so it leads me to think its an incorrectly pinned wire in the harness.
  7. #667
    The speedo harness wires were tied into the grey plug but went to a diff connector, you didn't chop those off right?
  8. #668
    No they are all still wired up
  9. #669
    06-13-2008
    Bronx, NY
    2,606
    People easy on stock internals. Lol
    SOHC Turbo
  10. #670
    Re: Greddy's build thread!! Better late than never!
    Our stock intervals aren't that weak. They can handle some power!! As long as they don't constantly beat on it.
    Back on topic. Jigs mentioned something about a better flowing head!! Care to elaborate there??
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  11. #671
    06-13-2008
    Bronx, NY
    2,606
    If you say so. Weak. Our Stock Internal are not for boost period. The only solid thing on the block is the crank.
    Baby it or not you still boost putting stress on it specially if you did not changed the main and rods bearings oem or race.
    When u start getting happy about 10psi and start think yeah good tune could go up easy 250+ is pushing it. My 2 cent. All im saying enjoy boost but dont start pushing the limit just because it works.
    SOHC Turbo
  12. #672
    Mild port on the head. Just cleaned up for better flow nothing huge guys i still have the stock tb so we'll see
  13. #673
    11-29-2009
    Chadds Ford, PA
    2,768
    Actually the weakest spot is the pistons. The rods are the same as the evos, the bearings are made from the same material as the evo's.
  14. #674
    06-13-2008
    Bronx, NY
    2,606
    ^my point is still "weak". Evos has smaller crank. The strokes are different. People are compering evos 2.0 and a 2.4 block internals. They both have different stroke. Dont matter is the bearing are made the same material or the same mold. Is still different setup.
    SOHC Turbo
  15. #675
    Ok well i only want like 220 whp if i blow this.motor im gonna part out.the.car lol
  16. #676
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    if you have a evo 8 ecu and your connected with lets say a a boomslang, the 8g ecu is an input and on the evo 8 ecu its an output your having mixed signals, that's why it jumps
    crank angle 100mm stroke to a 88mm piston, compared to something with a less stroke, its really down to how you want your setup, evo guys like the 2.3L setup,
    <a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&amp;current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
  17. #677
    tach and speedo fixed :) Can't decide if I wanna leave the pre facelift vr4 grill in place or not, I kinda like it
  18. #678
    02-17-2011
    i live in sunny florida
    1,240
    Can you get a pic of the uicp I like to see how close it is near the intake pipe,
    Sent from my PC36100 using Tapatalk 2
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  19. #679
    Nowhere near it i have tons of clearance
  20. #680
    clutch slips pretty hardcore in 3rd and 4th, car put down 208/254 whp/wtq, I'm pleased with the torque curve and it was only 13psi of boost.
