Thread: Post What You Did To Your Car or Bought Today!
Page 375 of 538 FirstFirst ... 275325365371372373374375376377378379385425475 ... LastLast
Showing results 7,481 to 7,500 of 10744
  1. #7481
    ^That will be awesome! I hope they do.
  2. #7482
    12-13-2010
    Brooklyn, Maryland
    4,638
    The LSD movement is gaining traction.....pun intended!
    ok, that was corny, I apologize
    #CruelSummer2013!! *clicks imaginary Like button*
    -Greg
  3. #7483
    Finished up my new audio install today
    Since the wall blocks my trunk light I added LED strips to each side to add some illumination.
    T.I. 04 BUILD YOUR OWN
  4. #7484
    Experienced TGC Member JDyal's Avatar
    02-08-2012
    Hackensack NJ
    1,146
    Got a nice wash and wax after a mud bath
    Lights on. Still waiting for my other fog light ballast from DDM that was faulty
    Put on my logo
    closeup
    Bought from crzygtz,deeznutz, dominicano, finald8ta, Galantman03, G-Spot, Isaurio, jonk8123, M-Rod, and specter6633
    Dont' keep it stock, turn heads on the block
    2003 Mitsubishi Galant ES 2.4L 4 cyl "Storm"
  5. #7485
    05-14-2010
    Coachella, CA
    5,954
    You know youre supposed to remove the clear part right?
  6. #7486
    I'm glad more people are getting LSDs, they make driving the cars so much better
  7. #7487
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Quote Originally Posted by M-Rod View Post
    Quote Originally Posted by wetamup2k3g View Post
    Quote Originally Posted by greddy View Post
    Yeah with all the LSD talk these days, Jigz's BabyG unfortunate situation and since I'm opening the trans due to a oil leak, I just want to take that off my list of concerns.
    4g64T 5spd
  8. #7488
    02-08-2012
    Hackensack NJ
    1,146
    Lol I figured that but I couldn't do it, when I peeled it a piece of the paper got stuck to it and I had to carefully peel that off
  9. #7489
    Small update, doing a first time retrofit with an unknown set of projectors I pulled from a yard.
  10. #7490
    i was thinking about snagging some dual projector audi heads from pick n pull.. thoughts? worth it or order just projectors online?
  11. #7491
    05-14-2010
    Coachella, CA
    5,954
    For jdm heads cant go wrong with either TSX or S2K projectors.
  12. #7492
    12-13-2010
    Brooklyn, Maryland
    4,638
    ^^S2K's are pricey, but SO worth it if you're an HID fiend like myself. Their output with a clear lens is perfect. Those and LS430's, can't be beat. However, THEY ARE NOT CHEAP!
    TSX's are good, TL's are worlds better (but hard to pull off cleanly), FX-R's are great, RX330's are great, especially with a curved shield mod, they're on par with the S2K's once you put a curved shield in.
    However, Audi HID's probably use the Hella design like the Mercedes E55's, BMW E46's, and Evo X's (which are the newest design) and those are all great projectors too, can't go wrong with either.
    If you get them from a pick-n-pull, check out the bowls, make sure they are clean, not oxidized, not scratched. All that kills output. If so, just head over to TRS and order some EVOX-R projectors if you're dead set on that style of projector, or any of the other ones they have, the Morimoto ones require little to no cutting to install. Hope this helps, good luck!
    I soooo need to move already so I can do my own retrofit....
    -Greg
  13. #7493
    that helps tons thanks!
  14. #7494
    Here it is, almost done with it. Need to adjust and clean the lens. (Ignore gaps, didn't bolt in right away as I need to change a few things beforehand)
  15. #7495
    06-16-2010
    Fort Mill, SC
    2,282
    Quote Originally Posted by OMEGA PHX View Post
    x2 mine is ziptied to the rad support side to side piece that's behind the grill and you can't see it
    #CruelSummer2013
    I think I might have bought a Quaife LSD, I'm still not sure because I don't know if they'll ship it to PR we'll see
    Why not run the harness under the top ledge of the core support? It would be nice and concealed.
    I'll do that when i go in to cut some more on the rad support, i was in a rush to get it going that night
    Anyone by chance have the clips for the bulbs on the JDM headlights
    Quote Originally Posted by dknight3 View Post
    What about the Mini H1's??
    -Andrew
  16. #7496
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    they should, PR is a US territory, I'll be joining the LSD club this summer as well
    got my ground wire kit in earlier today, I'm installing it Thursday
  17. #7497
    07-02-2011
    South Florida, by the beach
    1,076
    I know my engine bay is dirty but I finally put on the powder coated stuff spdracr did for me. New plugs and plug wires, new gaskets.
    The FSM said 39 inch pounds for the valve cover bolts, my torque wrench does foot pounds, so is inch pounds is pretty much a little bit over hand tight?
    Before
    After
    I'll get a day light pic after work, my flash kinda bleached out the purple, it looks better in the day light.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  18. #7498
    Installed a ebay oval muffler on Tuesday that replaced the N1 that basically fell apart.
    Then today i made a quick vid on how it sounds. In person its quieter then the N1 there's a hint of rasp at redline which i never hear under load. Overall its decently smooth and not obnoxious i can listen to my stereo now but still hear the muffler when im on the throttle..
  19. #7499
    05-03-2009
    1,465
    So the fedex guy came:
    Just ordered the speed gear and bearings ;)
    4g64T 5spd
  20. #7500
    06-13-2008
    Bronx, NY
    2,606
    ^ nice Good Shit. I'm still waiting to use mine. LOL
    The LSD is going to get a beating.
    SOHC Turbo
