Thread: Galantman03's 8G Build
Page 44 of 70 FirstFirst ... 3440414243444546474854 ... LastLast
Showing results 861 to 880 of 1392
  1. #861
    any updates?
  2. #862
    Quote Originally Posted by evo_powered_galant View Post
    any updates?
    He's still deployed.
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  3. #863
    Well Hellooooooo There!
    Some Pics Today.
    perfect Fit
  4. #864
    Looks like someone is on leave... Welcome back sir now finish that fuckin monster!
  5. #865
    12-13-2010
    Brooklyn, Maryland
    4,638
    YESSS! Let's do thisss!
    -Greg
  6. #866
    ID 2000s installed
    originally I wanted to have the sender unit on the pump side, BUT it wouldn't fit with the baffle inside the tank. I also ohmed out the gsx unit and it was bad. So being a mad scientist, I devised a plan. I used the galant sender unit as well as the fuel temp har har har. The pivot point of the float is pretty dang close the the gsx original location. Well me being picky I had to had a clean install right? so I used the connector, cut and soldered the wires that I needed. But I had to add a pin for the temp sender, and a left over pin for an injector fits perfect into the connector.
    -8 and -10 lines installed up to where the front subframe is installed. I waiting for a front subframe to come in, and I don't know the clearance for the hose yet, that's what the fuel lines aren't 100% installed.
    rear axles rated for 800 to 900 hp from what I was told
    was going to install them but I guess I forgot to order the rear boots lol so I have to wait on that.
    I also wired up 2 fuel pump rewire kits, and I need a little help as I am tired and can't seem to grasp this.
    It has me tap into the 12v pump power as the trigger, and then then other side of that on the relay goes the the pump itself. and then I have a lead wire for the battery. NOW, I have a ground on the relay, is it for the relay? or for the ground for the pump it self?
  7. #867
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by Galantman03 View Post
    ID 2000s installed
    Good progress.
    For the pump i know. Brian or Roman could help out with the pump wiring.
    SOHC Turbo
  8. #868
    Ground on the relay should be for the relay itself. The battery lead goes in then out since the relay is simply a switch for the pump circuit, it'll be a + cable going in and out so the one ground on the relay is for your relay trip circuit.
  9. #869
    ok cool so that means the gounds from the pumps go to the harness side ground (the original ground for the original pump)
  10. #870
    05-14-2010
    Coachella, CA
    5,954
    ^^^ You could say that. Long story short the pump and the relay need to be grounded to the car, not to each other.
  11. #871
    Ohhhhh its about that time again! *rubs hands together*
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  12. #872
    Welcome back! How soon do you expect it to have this thing on the road?
  13. #873
    Yeah, I couldn't find the diagram on my computer....
    Quote Originally Posted by Ivory8g View Post
    Mmmhmmm! You know it! muahahaha! BTW Dude, that catch can is epic! lol
    Quote Originally Posted by M-Rod View Post
    Thanks Matt. Well like always, I would like to ASAP. BUT I'm waiting on 5 things right now, my fricken manifold that I ordered in April, my tcase with a wave trac, front subframe that should be done in about 2 weeks, and the driveshaft. after that its exhaust and piping and then start her up. I would like to have it done and started tuning end of sept, but we shall see how that pans out. lol
  14. #874
    08-08-2004
    Las Vegas
    2,098
    lookin good. whats the length on that intercooler endtank to endtank not including the in and outlet. it looks like it fits perfect
  15. #875
    dude 35 inches end tank to end tank. 26 x 12 x 4 is the core size. 44 inches total length. it fits like a glove its perfect haha
  16. #876
    Heck yeah! Cant wait to see it in the bay. Man we got it done in the nick of time cause that guy left and is travelling now lol.
  17. #877
    Well finally got around to take the stuff in to get it welded. intercooler is still there getting 2 more brackets welded up.
    Also ran into a snag. I have a gsx rear sway bar and then yesterday I had me sway bar arms or lower control arms come in and no matter which way I move the bar or even flip it around, the sway bar hits the cv boot. what gives? ( I know the bar is installed wrong in the pic)
  18. #878
    Now that's fuckin weird... I had a problem that the car was so low that the rrm swaybar sat on the control arm and bent one of them, but that was it. Look at my pics and see if you are missing something
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
  19. #879
    How low are you trying to go with it? I've only seen that happen when they're damn near laying frame.
    What kind of tie bars are those?
  20. #880
    those are Cali's adjustable toe arms. work pretty cool
    my work around on the sway bar issue.
    and the wavetrac has arrived.
Tags for this Thread
